Sensing Info 传感器资讯
Tip of my blog
   www.xgmh88.com
www.bxj688.com
www.mrzzg.com
www.750127.com
特别声明:本博客内容不允许随意转载,有需要请联系,如果本博客内容损害了您的权利,请联系我,我们会做相关处理或删除.
更多更详细的内容请点击
New态氧分压变送器(氧含量分析仪) ZH420-O推出
世界知名的气体分析监控仪表传感器,在气体仪器仪表行业我们将提供更全面更专业的技术支持和服务,并提供更优秀的产品.
阅读(6541) 评论(2)
标签(TAG):传感器
Basic Pressure Sensors
  • 0...2.5 mbar to 0...20 bar,
    0...1 inch H2O to 0...300 psi
  • Absolute, (vacuum) gage, differential
  • Output: mV
  • For air and non-corrosive gases or lightly corrosive liquids and gases
Compensated and Calibrated Pressure Sensors
  • 0...2.5 mbar to 0...10 bar,
    0...1 inch H2O to 0...150 psi
  • Output: mV
Amplified Pressure Sensors
  • 0...1 mbar to 0...35 bar,
    0...0.4 inch H2O to 0...500 psi
  • Barometric pressure ranges
  • Absolute, gage, differential
  • Output: 0.25...4.25 V, 0.5...4.5 V, 0...5 V,
    1...6 V, 4...20 mA, I²C bus
Barometric Pressure Sensors
  • 500...1080 or 800...1100 mbar, 12...16 psia
  • Absolute
  • Output: 0.5...4.5 V, 0...5 V, I²C bus
Pressure Sensors for Lightly Corrosive Liquids and Gases
  • 0...35 mbar to 0...35 bar,
    0...0.5 to 0...500 psi
  • Output: mV, 0.5...4.5 V
  • Enhanced media compatibility
Stainless Steel Pressure Sensors
  • 0...175 mbar to 0...350 bar,
    0...3 to 0...5000 psi
  • Output: mV
  • For media compatible with stainless steel
Pressure Transducers with mV-Output for Corrosive Media
  • 0...200 mbar to 0...1400 bar,
    0...3 to 0...20.000 psi
  • Absolute or (vacuum) gage pressure
  • Output: mV
Low Pressure Transmitters
  • 0...1 mbar to 0...20 bar and 0...±1 mbar to 0...±1 bar, 0...1 inch H2O to 0...300 psi and 0...±1 inch H2O to 0...±15 psi
  • Output: 0.5...4.5 V, 0...5 V, 0...10 V, 1...6 V,
    4...20 mA
Pressure Transmitters for Corrosive Liquids and Gases
  • Output: 4...20 mA, 0...20 mA, 0...5 V,
    0...10 V, 0.5...4.5 V, 1...6 V
  • For corrosive and aggressive media
Hydrostatic Liquid Level Sensors
  • 0...100 mbar to 0...10 bar, 0...1.5 to 0...150 psi
    0...1 to 0...100 mH2O, 0...3.5 to 0...350 ft H2O
  • Absolute, gage
  • Output: 4...20 mA, 0...20 mA, 0...10 V, 1...6 V
  • For level measurement
Optical Liquid Level Switches
  • Single point liquid level detection
  • No moving parts
  • High media compatibility
  • Miniature size
  • Fast response
  • Basic, digital or transistor output
Ultrasonic liquid level sensors
  • Non-invasive pulsed ultrasonic technology
  • No media compatibility or sterility issues
  • Solid state design, no moving parts
  • High electrical noise immunity
Ultrasonic Air Bubble and Air-In-Line Detectors
Fluid Monitoring Sensors for Medical Applications
  • Ultrasonic drip chamber liquid level detectors
  • Optical blood leak and blood component detectors
  • For many critical patient-related medical device applications
  • Non-invasive technology
Oxygen Sensors
Oxygen Sensors
  • Non-consumptive zirconium dioxide technology
  • High stability and accuracy
  • Calibration and functional test without reference gas
  • No cross-sensitivity to most other gases
Force Sensors
  • 0...350 mbar to 0...2 bar,
    0...1.5 lbs, 0...3 lbs or
    0...1500 g
  • Output: mV, 1...4 V
Force Sensors
Mass Flow Sensors for Gases
  • From 0...±25 sscm to 0...200 slpm or
    from 0...0.5 to 0...±4 inch H2O
  • Output: mA, mV, V
  • For air and dry gases
Sensors for Volumetric Flow Measurement
  • Ultra low differential pressures from ±1 mbar
  • Wet-wet differential pressure measurement
  • Square rooted output signals
High Performance Miniature Valves
  • Switching and proportional solenoid valves
  • For gases and liquids
  • 2-way or 3-way configurations
  • Normally open, normally closed or distributor
  • Pressure ranges from 0...6 to 0...150 psi (0...0.4 to 0...10 bar), vacuum 0...-27 inHg (0...-900 mbar)
  • Low power consumption
Highly Media Resistant Valves
  • Switching solenoid valves
  • For aggressive gases and liquids
  • Pressure ranges from vacuum to 1250 psi (86 bar)
Electronic Pressure Controllers
  • Pressure ranges up to 100 psi (7 bar)
  • Vacuum ranges
  • For non-corrosive gases
Miniature Diaphragm Pumps
  • Ideal for use in portable air and gas applications
  • Deliver up to 65 slpm
  • Operating pressures up to 22 psig (1.5 bar) and vacuum up to 22 inHg (750 mbar)
Semi-Custom and Custom Products
    Specification range:
  • From miniature sensors to complex fluidic control systems
  • For air, gas and liquid media
  • All analog and digital output signals
  • Custom housings and assemblies
  • Ultra small size or heavy duty
  • Any media connection and electrical termination
by admin 发表于:2007/6/28 9:08:00
回复:传感器大全集萃
引用 | 举报回复
请问20KG的重量要用哪一种传感器
by 段(游客) 发表于:2007/10/26 20:44:34
My subject | 我的主题
New entries | 新发表
Messages Board | 留言板
Guest Comments | 新评注
Blogger Login | 登陆栏
Blog Infomation | 信息栏
博客名称:传感器资讯博客-Sensing Info 日志总数:102 评论数量:40 访问次数:541915 建立时间::2006年01月16日
Blog Infomation | 搜索栏
Blog Infomation | 收藏栏
XML RSS 2.0
© COPYRIGHT 2004 ALL RIGHTS RESERVED http://www.gkong.com
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
