航空用逻辑IC
概述电子档:
抗辐射AC/ACT: 5V先进高速CMOS抗辐射AC/ACT: 5V先进高速CMOS
抗辐射CMOS 4000B系列4000抗辐射CMOS 4000B系列4000
抗辐射HC/HCT抗辐射HC/HCT
抗辐射VCX: 超低电压16位总线接口抗辐射VCX: 超低电压16位总线接口
型号概述
54AC00Rad-Hard Quad 2-Input NAND Gate
54AC02Rad-Hard Quad 2-Input NOR Gate
54AC04Rad-Hard Hex Inverter
54AC08Rad-Hard Quad 2-Input AND Gate
54AC10Rad-Hard Triple 3-Input NAND Gate
54AC11Rad-Hard Triple 3-Input AND Gate
54AC138Rad-Hard 3 to 8 Line Decoder (Inv.); Rad-Hard 3 to 8 Line Decoder Inverter
54AC139Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
54AC14Rad-Hard Hex Schmitt Inverter
54AC151Rad-Hard 8-Channel Multiplexer
54AC157Rad-Hard Quad 2-Channel Multiplexer
54AC161Rad-Hard Synchronous Binary Counter With Async. Clear
54AC16244Rad-Hard 16-bit Transceiver Non Inverting
54AC16245Rad-Hard 16-bit Transceiver 3-state Inverting
54AC16373Rad-Hard 16-bit D-Type Latch 3-state
54AC16374Rad-Hard 16-bit D-Type Flip Flop 3-state
54AC164245Rad-Hard 16-bit transceiver, 3.3 to 5 V bidirectional level shifter transceiver
54AC174Rad-Hard Hex D-Type Flip-Flop With Clear; Rad-Hard Hex D-Type Flip-Flop with Clear
54AC191Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
54AC240Rad-Hard Octal Bus Buffer (3-State/Inv.); Rad-Hard Octal Bus Buffer 3-state Inverter
54AC244Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
54AC245Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-state
54AC2525Rad-Hard 1-to-8 Skew Clock Driver
54AC273Rad-Hard Octal D-Type Flip-Flop With Clear; Rad-Hard Octal D-Type Flip-Flop with Clear
54AC32Rad-Hard Quad 2-Input OR Gate
54AC373Rad-Hard Octal D-Type Latch (3-State); Rad-Hard Octal D-Type Latch 3-state
54AC374Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
54AC521Rad-Hard 8-bit Comparator with Enable
54AC540Rad-Hard Octal Buffer/Line Driver 3-State
54AC541Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
54AC574Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
54AC74Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
54AC86Rad-Hard Quad Exclusive OR Gate; Rad-Hard Quad exclusive OR
54ACT00Rad-Hard Quad 2-Input NAND Gate
54ACT02Rad-Hard Quad 2-Input NOR Gate
54ACT04Rad-Hard Hex Inverter
54ACT08Rad-Hard Quad 2-Input AND Gate
54ACT10Rad-Hard Triple 3-Input NAND Gate
54ACT11Rad-Hard Triple 3-Input AND Gate
54ACT138Rad-Hard 3 to 8 Line Decoder (Inv.); Rad-Hard 3 to 8 Line Decoder Inverter
54ACT139Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
54ACT14Rad-Hard Hex Schmitt Inverter
54ACT151Rad-Hard 8-Channel Multiplexer
54ACT157Rad-Hard Quad 2-Channel Multiplexer
54ACT161Rad-Hard Synchronous Binary Counter With Async. Clear
54ACT16244Rad-Hard 16-bit Transceiver Non Inverting
54ACT16245Rad-Hard 16-bit Transceiver 3-state Inverting
54ACT16373Rad-Hard 16-bit D-Type Latch 3-state
54ACT16374Rad-Hard 16-bit D-Type Flip-Flop 3-state
54ACT174Rad-Hard Hex D-Type Flip-Flop With Clear; Rad-Hard Hex D-Type Flip-Flop with Clear
54ACT191Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
54ACT240Rad-Hard Octal Bus Buffer (3-State/Inv.); Rad-Hard Octal Bus Buffer 3-state Inverter
54ACT244Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
54ACT245Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-state
54ACT273Rad-Hard Octal D-Type Flip-Flop With Clear; Rad-Hard Octal D-Type Flip-Flop with Clear
54ACT32Rad-Hard Quad 2-Input OR Gate
54ACT373Rad-Hard Octal D-Type Latch (3-State); Rad-Hard Octal D-Type Latch 3-state
54ACT374Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
54ACT541Rad-Hard Octal Bus Buffer (3-State); Rad-Hard Octal Bus Buffer 3-state
54ACT574Rad-Hard Octal D-Type Flip-Flop (3-State); Rad-Hard Octal D-Type Flip-Flop 3-state
54ACT74Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
54ACT86Rad-Hard Quad Exclusive OR Gate; Rad-Hard Quad exclusive OR
抗辐射CMOS 4000B系列4000
型号概述
HCC4001BRad-hard quad 2-input NOR gate
HCC4002BRad-hard dual 4-input NOR gate
HCC4008BRad-hard 4-bit full adder
HCC40103BRad-hard presettable 8-bit binary down counter
HCC40106BRad-hard hex schmitt trigger
HCC40107BRad-hard dual 2-input NAND buffer/driver
HCC40109BRad-hard quad low-to-high voltage level shifter
HCC4011BRad-Hard Quad 2-Input NAND Gate
HCC4012BRad-Hard Dual 4-Input NAND Gate; Rad-hard dual 4-input NAND gate
HCC4013BRad-Hard Dual D Flip-Flop
HCC4014BRad-hard 8-stage static synchronous shift register
HCC4015BRad-hard dual 4-stage static shift register
HCC40161BRad-Hard Binary Counter with Asynchronous Clear
HCC4016BRad-Hard Quad Bilateral Switch
HCC40174BRad-Hard Hex D Flip-Flop
HCC4017BRad-Hard Decade Counter/Divider
HCC4018BRad-hard presettable divide-by N counter
HCC40193BRad-hard presettable 4-bit binary up-down counter
HCC4019BRad-Hard Quad AND/OR Select Gate; Rad-hard quad AND/OR select gate
HCC4020BRad-hard 14-stage binary/ripple counter
HCC4021BRad-hard 8-stage static shift register
HCC4022BRad-Hard Divide-By-8 Counter/Divider
HCC4023BRad-hard triple 3-input NAND gate
HCC4024BRad-hard 7-stage binary/ripple counter
HCC4025BRad-Hard Triple 3-Input NOR Gate
HCC4027BRad-hard dual J-K master-slave Flip-Flop
HCC4028BRad-hard BCD-to-decimal decoder
HCC4029BRad-hard presettable up/down counter
HCC4030BRad-hard quad exclusive OR gate
HCC4034BRad-hard 8-stage static bidirectional bus register
HCC4035BRad-hard 4-stage parallel I/O shift register
HCC4040BRad-hard 12-stage binary/ripple counter
HCC4041UBRad-hard quad true/complement buffer
HCC4042BRad-hard quad clocked D latch
HCC4043BRad-hard quad 3-state NOR R/S latch
HCC4044BRad-Hard Quad 3-State NAND R/S Latch
HCC4046BRad-hard micropower phase locker loop
HCC4047BRad-hard monostable/astable multivibrator
HCC4049UBRad-hard hex inverting buffer/converter
HCC4050BRad-hard hex non-inverting buffer/converter
HCC4051BRad-hard single 8-channel analog mux/demux
HCC4052BRad-hard different 4-channel analog mux/demux
HCC4053BRad-hard triple 2-channel analog mux/demux
HCC4060BRad-hard 14-stage counter/divider AND oscillator
HCC4063BRad-hard 4-bit magnitude comparator
HCC4066BRad-hard quad bilateral switch
HCC4067BRad-hard single 16-channel analog mux/demux
HCC4068BRad-hard 8-input NAND/AND gate
HCC4069UBRad-hard hex inverter
HCC4070BRad-hard quad exclusive OR gate
HCC4071BRad-hard quad 2-input OR gate
HCC4072BRad-hard dual 4-input OR gate
HCC4073BRad-hard triple 3-input AND gate
HCC4075BRad-hard triple 3-input OR gate
HCC4076BRad-hard 4-bit D-type register
HCC4077BRad-hard quad exclusive NOR gate
HCC4078BRad-hard 8-input NOR/OR gate
HCC4081BRad-hard quad 2-input AND gate
HCC4082BRad-hard dual 4-input AND gate
HCC4093BRad-hard quad 2-input NAND Schmitt trigger
HCC4094BRad-hard 8-stage shift-and-store bus register
HCC4098BRad-hard dual monostable multivibrator
HCC4099BRad-hard 8-bit addressable latch
HCC4502BRad-hard strobed hex inverter/buffer
HCC4503BRad-Hard Hex Buffer (3-State Non-Inverter); Rad-hard hex buffer 3-state non-inverter
HCC4508BRad-hard dual 4-bit Latch 3-state outputs
HCC4512BRad-hard 8-channel data selec. with 3-state output
HCC4514B4-Bit Latch/4-To-16 Line Dec. (Out. High); Rad-hard 4-bit Latch / 4-to-16 line decoder output high
HCC4515B4-Bit Latch/4-To-16 Line Dec. (Out. Low); Rad-hard 4-bit Latch / 4-to-16 line decoder output low
HCC4516BRad-hard presettable 4-bit binary up/down counter
HCC4520BRad-hard dual binary up-down counter
HCC4532BRad-hard 8-input priority encoder
HCC4538BRad-Hard Dual Precision Monostable Multivibrator; Rad-hard dual precision monostable multivibrator
HCC4555BRad-Hard Dual 1-Of-4 Decoder/Demultiplexer (Out. High); Rad-hard dual 1-of-4 decoder/demux output high
HCC4556BRad-Hard Dual 1-of-4 Decoder/Demultiplexer (Out. Low); Rad-hard dual 1-of-4 decoder/demux output low
抗辐射HC/HCT
型号概述
M54HC00Rad-Hard Quad 2-Input NAND Gate
M54HC02Rad-Hard Quad 2-Input NOR Gate
M54HC03Rad-Hard Quad 2-Input NAND (Open Drain)
M54HC04Rad-Hard Hex Inverter
M54HC08Rad-Hard Quad 2-Input AND Gate
M54HC10Rad-Hard Triple 3-Input NAND Gate
M54HC109Rad-Hard Dual J-K Flip-Flop With Preset & Clear
M54HC11Rad-Hard Triple 3-Input AND Gate
M54HC123Rad-Hard Dual Retrigg. Monostable Multivibrator with Clear
M54HC125Rad-Hard Quad Bus Buffer (3-State)
M54HC132Rad-Hard Quad 2-Input Schmitt NAND Gate
M54HC137Rad-Hard 3 to 8 Line Decoder Latch (Inv.); Rad-Hard 3-to-8 Line Decoder Latch Inverter
M54HC138Rad-Hard 3 to 8 Line Decoder (Inv.)
M54HC139Rad-Hard Dual 2 to 4 Line Decoder/Demultiplexer
M54HC14Rad-Hard Hex Schmitt Inverter
M54HC148Rad-Hard 8-to-3 Line Priority Encoder
M54HC151Rad-Hard 8-Channel Multiplexer
M54HC153Rad-Hard Dual 4-Channel Multiplexer
M54HC154Rad-Hard 4 to 16 Line Decoder/Demultiplexer
M54HC157Rad-Hard Quad 2-Channel Multiplexer
M54HC158Rad-Hard Quad 2-Channel Multiplexer (Inverting)
M54HC160Rad-Hard Synchronous Decade Counter With Async. Clear
M54HC161Rad-Hard Synchronous Binary Counter With Async. Clear
M54HC163Rad-Had MSynchronous Binary Counter With Sync. Clear
M54HC164Rad-Hard 8 Bit SIPO Shift Register
M54HC165Rad-Hard 8 Bit PISO Shift Register
M54HC166Rad-Hard 8 Bit PISO Shift Register
M54HC174Rad-Hard Hex D-Type Flip-Flop with Clear
M54HC175Rad-Hard Quad D-Type Flip-Flop With Clear
M54HC191Rad-Hard 4 Bit Synchronous Binary Up/Down Counter
M54HC193Rad-Hard Synchronous Up/Down Binary Counter
M54HC194Rad-Hard 4-bit PIPO Shit Register
M54HC20Rad-Hard Dual 4-Input NAND Gate
M54HC21Rad-Hard Dual 4-Input AND Gate
M54HC237Rad-Hard 3 to 8 Line Decoder Latch; Rad-Hard 3-to-8 Line Decoder Latch
M54HC240Rad-Hard Octal Bus Buffer (3-State/Inv.)
M54HC241Rad-Hard Octal Bus Buffer (3-State)
M54HC244Rad-Hard Octal Bus Buffer (3-State)
M54HC245Rad-Hard Octal Bus Transceiver (3-State)
M54HC251Rad-Hard 8-Channel Multiplexer (3-State)
M54HC253Rad-Hard Dual 4-Channel Multiplexer (3-State)
M54HC257Rad-Hard Quad 2-Channel Multiplexer (3-State)
M54HC259Rad-Hard 8-bit Adressable Latch
M54HC27Rad-Hard Triple 3-Input NOR Gate
M54HC273Rad-Hard Octal D-Type Flip-Flop with Clear
M54HC283Rad-Hard 4-bit Binary Full Adder
M54HC30Rad-Hard 8-Input NAND Gate
M54HC32Rad-Hard Quad 2-Input OR Gate
M54HC365Rad-Hard Hex Bus Buffer (3-State)
M54HC367Rad-Hard Hex Bus Buffer (3-State)
M54HC373Rad-Hard Octal D-Type Latch (3-State)
M54HC374Rad-Hard Octal D-Type Flip-Flop (3-State)
M54HC393Rad-Hard Dual Binary Counter
M54HC4002Rad-Hard Dual 4-Input NOR Gate
M54HC4020Rad-Hard 14-Stage Binary Counter
M54HC4040Rad-Hard 12-Stage Binary Counter
M54HC4049Rad-Hard Hex Buffer/Converter (Inv.)
M54HC4050Rad-Hard Hex Buffer/Converter
M54HC4051Rad-Hard Single 8-Channel Analog Multiplexer/Demultiplexer
M54HC4053Rad-Hard Triple 2-Channel Analog Multiplexer/Demultiplexer; Rad-Hard Triple 2-Channel Analog Mux/Demux
M54HC4060Rad-Hard 14-Stage Binary Counter/Oscillator
M54HC4066Rad-Hard Quad Bilateral Switch
M54HC4072Rad-Hard Dual 4-Input OR Gate
M54HC4075Rad-Hard Triple 3-Input OR Gate
M54HC4078Rad-Hard 8-Input Nor/OR Gate
M54HC4094Rad-Hard 8-bit SIPO Shit Register 3-State
M54HC4514Rad-Hard 4 to 16 Line Decoder Latch
M54HC540Rad-Hard Octal Bus Buffer (3-State/Inv.)
M54HC541Rad-Hard Octal Bus Buffer (3-State)
M54HC573Rad-Hard Octal D-Type Latch (3-State)
M54HC574Rad-Hard Octal D-Type Flip-Flop (3-State)
M54HC590Rad-Hard 8 Bit Binary Counter Register (3-State)
M54HC595Rad-Hard 8 Bit Shift Register Output Latch (3-State)
M54HC597Rad-Hard 8 Bit Latch Shift Register; Rad-Hard 8 Bit Latch/Shift Register
M54HC688Rad-Hard 8 Bit Equality Comparator
M54HC73Rad-Hard Dual J-K Flip-Flop With Clear
M54HC74Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
M54HC75Rad-Hard 4-Bit D-Type Latch
M54HC85Rad-Hard 4-Bit Magnitude Comparator
M54HC86Rad-Hard Quad Exclusive OR Gate
M54HCT240Rad-Hard Octal Bus Buffer 3-State Inverter
M54HCT244Rad-Hard Octal Bus Buffer (3-State)
M54HCT245Rad-Hard Octal Bus Transceiver (3-State); Rad-Hard Octal Bus Transceiver 3-State
M54HCT373Rad-Hard Octal D-Type Latch 3-State
M54HCT374Rad-Hard Octal D-Type Flip-Flop 3-State
M54HCT74Rad-Hard Dual D-Type Flip-Flop With Preset & Clear
M54HCU04Rad-Hard Hex Inverter Single Stage
抗辐射VCX: 超低电压16位总线接口
型号概述
54VCXH162244Rad-Hard 16-bit Transceiver Non Inverting
54VCXH162245Rad-Hard 16-bit Transceiver 3-state Non Inverting
54VCXH162373Rad-Hard 16-bit D-Type Latch 3-state
54VCXH162374Rad-Hard 16-bit D-Type Flip-Flop 3-state
54VCXH163245Rad-hard 16-bit transceiver, 1.8 V to 3.3 V bi-directional level shifter
54VCXHR162245Rad-Hard 16-bit Transceiver Non Inverting with Resistor
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
