MEMS 加速计
Find MEMS Accelerometers and iSensor MEMS Accelerometer Subsystems that reliably detect and measure acceleration, tilt, shock and vibration in performance-driven applications. ADI’s MEMS accelerometer specifications lead the industry in power, noise and bandwidth, and the portfolio offers a range of MEMS sensor and signal processing integration on chip. Download the ADXL345 MEMS Accelerometer datasheet or the MEMS accelerometer applications note, “Using an Accelerometer for Inclination Sensing” . Order evaluation boards, leverage simulation models and download Circuits from the Lab reference designs.
MEMS Accelerometer
Part# Results: 18 # of Axes Range Typical Bandwidth (kHz) Sensitivity Sensitivity Accuracy (%) Output Type Noise Density (µg/rtHz) Voltage Supply (V) Supply Current Temp Range (°C) Package
ADXL212 2 +/- 2g 0.5 12.5 %/g 12.5 Digital - 3 to 5.25 700µA -40 to 85°C 8-Lead LCC
ADXL206 2 +/- 5g - 312 mV/g - Analog 110 4.75 to 5.25 700µA -40 to 175°C 8-Lead SBDIP
ADXL312 3 +/- 12 g 1.6 345 LSB/g - Digital 340 2.0 to 3.6 170µA -40 to 105°C 5mm x 5mm LFCSP
ADXL337 3 +/- 3.6g 1.6 300 mV/g - Analog 175 1.8 to 3.6 300µA -40 to 85°C 3mm x 3mm LFCSP
ADXL325 3 +/- 5g 1.6 174 mV/g 10 Analog 250 1.8 to 3.6 350µA -40 to 85°C 4mm x 4mm LFCSP
ADXL326 3 +/- 16g 1.6 57 mV/g 10 Analog 250 1.8 to 3.6 350µA -40 to 85°C 4mm x 4mm LFCSP
ADXL327 3 +/- 2g 1.6 420 mV/g 10 Analog 250 1.8 to 3.6 350µA -40 to 85°C 4mm x 4mm LFCSP
ADXL346 3 +/- 2/4/8/16g 1.6 up to 256 LSB/g 10 Digital - 1.7 to 2.75 145µA -40 to 85°C 3mm x 3mm x 0.95 mm LGA
ADXL345 3 +/- 2/4/8/16g 1.6 up to 256 LSB/g 10 Digital - 2.0 to 3.6 145µA -40 to 85°C 3mm x 5mm x 1mm LGA
ADXL001 1 +/- 70g 22 16 mV/g (+/- 70g) - Analog 4000 3.135 to 6 5mA -40 to 125°C 5mm x 5mm Ceramic LCC
ADXL335 3 +/- 3g 1.6 300 mV/g 10 Analog 300 1.8 to 3.6 350µA -40 to 85°C 4mm x 4mm LFCSP
ADXL180 1 50 g to 500 g 0.8 0.125 g/LSB (50 g), 1.25 g/LSB (500 g) - Digital - 5 to 14.5 7.7mA -40 to 125°C CP-16
ADXL103 1 +/- 1.7g 2.5 1000 mV/g 4 Analog 110 3 to 6 700µA -40 to 125°C 5mm x 5mm x 2mm LCC
ADXL203 2 +/- 1.7g 2.5 1000 mV/g 4 Analog 110 3 to 6 700µA -40 to 125°C 5mm x 5mm x 2mm LCC
ADXL213 2 +/- 1.2g 2.5 30 %/g 10 PWM 160 3 to 6 700µA -40 to 85°C 5mm x 5mm x 2mm LCC
ADXL193 1 +/- 250g 0.4 8 mV/g 5 Analog 5000 4.75 to 5.25 1.5mA -40 to 125°C E-8
ADXL278 2 +/- 70g 0.4 27mV/g 5 Analog 1800 4.75 to 5.25 2.2mA -40 to 105- 5mm x 5mm Ceramic LCC
ADXL78 1 +/- 70g 0.4 27mV/g 5 Analog 1800 4.75 to 5.25 1.3mA -40 to 105- 5mm x 5mm Ceramic LCC
iSensor MEMS Accelerometer Subsytems
Part# Results: 12 Product Description Output Type Sensing Axes Typical Bandwidth (kHz) Voltage Supply (V) Range Sensitivity Sensitivity Accuracy (%) Temp Range (°C) Package
ADIS16228 Digital Triaxial Vibration Sensor with FFT Analysis and Storage SPI X, Y, Z 5 3.15 to 3.6 - - 6 -40 to 125°C -
ADIS16210 Precision Triaxial Inclinometer and Accelerometer with SPI SPI X, Y, Z 0.05 3.15 to 3.6 +/- 1.7g - 0.21 -40 to 85°C -
ADIS16227 Digital TriAxial Vibration Sensor with FFT Analysis and Storage SPI X, Y, Z 9 - +/- 70g - 5 -40 to 125°C -
ADIS16223 Digital Tri-axial Vibration Sensor SPI X, Y or Z 14.25 3.15 to 3.6 +/- 70g 4.768 mg/LSB 5 -40 to 125°C -
ADIS16220 PROGRAMMABLE DIGITAL VIBRATION SENSOR SPI X 1 3.15 to 3.6 +/- 70g 19.073 mg/LSB - -40 to 125°C 9.2mm x 9.2mm LGA
ADIS16240 Programmable Hi-G Digital Accelerometer, Impact Sensor SPI X, Y, Z 1.6 2.4 to 3.6 +/- 18g 51.4 mg/LSB - -40 to 105°C 12 mm x 12 mm BGA
ADIS16209 High Accuracy (0.1°), Dual-Axis Digital Accelerometer/Inclinometer SPI X, Y 0.05 3 to 3.6 +/- 90° or +/- 180° 0.025 °/LSB 0.4 -40 to 125°C 9 mm x 9mm LGA
ADIS16204 Programmable Hi-G Digital Accelerometer, Impact Sensor SPI X, Y 0.4 3 to 3.6 +/- 70g X & +/- 37g Y 17.13 mg/LSB - -40 to 105°C 9 mm x 9mm LGA
ADIS16203 Programmable Single Axis 360° Inclinometer SPI Z 2.25 3 to 3.6 +/- 180° 0.025 °/LSB - -40 to 125 9 mm x 9mm LGA
ADIS16006 Dual Axis ±5g Accelerometer with SPI Interface SPI X, Y 2.25 3 to 5.25 +/- 5g 3.91 mg/LSB 6 -40 to 125°C 7mm x 7mm LGA
ADIS16201 Programmable Dual Axis Accelerometer/Inclinometer SPI X, Y 2.25 3 to 3.6 +/- 1.7g 0.10 °/LSB 1 -40 to 125 9 mm x 9mm LGA
ADIS16003 Dual Axis ±1.7g Accelerometer with SPI Interface SPI X, Y 2.25 3 to 5.25 +/- 1.7g 1.22 mg/LSB 7 -40 to 125°C 7mm x 7mm LGA
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
