自控工程设计
:: 信息 公告 ::
推荐国外自控工程设计网站
Instrumentation and Control Engineering
:: 时间 记忆 ::
:: 最新 发表 ::
:: 最新 回复 ::
:: 最新 留言 ::
:: 用户 登入 ::
:: 日志 搜索 ::
:: 友情 链接 ::
:: 博客 信息 ::
博客名称:自控工程设计 日志总数:218 评论数量:128 访问次数:534913 建立时间::2006年09月01日
XML RSS 2.0
[概念] 球阀的类型 Types of ball valve
[ 2013/12/22 16:27:13 | By: InstrEng.com ]
For Ball Valve, there are 2 types design "Floating type" & "Trunnion type".
  • Float ball valve: the ball is held on two seat rings.
  • Trunnion ball valve: the ball is supported on its vertical rotation axis by a trunnion. The trunnion absorbs the pressure from the flow, therefore the contact between the ball and the seat is not excessively stressed and the operating torque can remain low. This design is recommend for big diameters and high pressure.
The left-hand photograph shows the construction of float ball valve, Floating ball is that ball pinched by 2pcs of ball seats and sealed. Ball is not fixed position.
while the right-hand photograph shows the construction of trunnion ball valve, Trunnion Ball is fixed position by upper and lower stems, and sealed for ball seats pushed to the ball by spring and fluid's pressure.
Click image for larger version.
Name:	floating ball valve.gif
ID:	934Click image for larger version.
Name:	trunnion ball valve.gif
Read more: http://www.instreng.com/category/shutdown-valves/
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
