My Blog! blog.gkong.com
Tip of my blog
新年快乐!
阅读(3788) 评论(0)
标签(TAG):
Keyword: 1)比较了PIC和AVR ;
               2) 文章是日期很新:May 17, 2011 20:07;
               3) 仅当看看外国人是怎么比较PIC和AVR的就行, 个人感觉作者心理上偏向
              了AVR, 很多观点个人持不同意见.
接录自: http://www.ladyada.net/library/picvsavr.html
PIC vs. AVR Ultimate fight!
OK, I know what you people want. You want ultimate fighting, embedded E.E. style. You want to know WHICH IS BETTER, PIC OR AVR?
Well, I know what side I'm placing my bets on (AVR of course) but for 99% of beginners, it doesn't matter too much which way you start.
Regardless, I'm tired of answering the same questions over & over, so here we go!
Wait, what?
In the last few years, D.I.Y. electronics has taken a major leap forward with the introduction of powerful yet low-cost, easy-to-program microcontrollers. In this case I'll be talking about 8-bit micros, since those are so popular. These chips cost a couple dollars, around $5, can be programmed with a PC and a cheap programmer (usually on the order of $30). They often have a few K of program ROM, around 1/2K of RAM and some EEPROM. Theres some 'peripherals' such as built in PWM, timers, A/D converters, etc.
Right now there are two major 'houses' of microcontrollers: the Microchip PIC family and the Atmel AVR family. I have no idea what PIC or AVR stand for (wikipedia sez: "Peripheral Interface Controller" and "Advanced Virtual RISC" respectively) There's also the T.I. MSP430 which I've heard good things about from friends who have done development on it, but not enough to put it in here, and the Silabs micros which are awesome but not really for the amateur market.
I am not really an expert here, so please help me fill in this page with more useful info, post it in forum! and make the topic something like "PIC v. AVR". Please keep in mind that this page was originally written in 2004.Thanks!
Packages
This is the first point, one which I think is pretty important. If you're doing one off/prototype projects, you'll want a chip thats easy to work with. That means DIP packaging.
Luckily, both AVR & PIC have lots of chips in DIP packages.
Winner? Its a tie!
Price
Price is a tough one to compare because sometimes one chip will have more peripherals or RAM. So I'll compare three chip-sets, an 8-pin chip, a ~20-pin chip and a 40-pin chip. They're also comparable in 'power,' but you'll have to trust me on that. Prices are for single pieces from Digikey
8-pin: PIC12F629 ($1.29) v. ATtiny13 ($1.40)
~20-pin: PIC16F628 ($3.35) v. ATtiny2313 ($2.26)
40-pin: PIC18F452 ($10.35) v ATmega32 ($8.17)
Winner? I think the numbers are pretty comparable. So I'm going to call it a tie.
Languages
Parlez-vous turing completeness? If you cant use your language of choice, its going to take a lot longer to get up to speed with your micro. Here are some common languages & commentary.
Assembly: OK, yes of course you can write in assembly code. Both PIC and AVR have free assemblers available by default from Microchip (MPLab) and Atmel (AVRTools) for Windows. For AVR, there is also a free unix command line assembler avra so you can run it under MacOS X (which I've done successfully) or Linux. Likewise, PICs have gpasm, which I've never used but I assume works good.
Overall, I've written some asm for both processors and I hate to break it to PIC users but writing assembly for PIC is akin to stabbing myself in the face. (Except its not even that efficient, cause you have to more the knife into the working register first (movlw KNIFE), and then you can stab yourself (movwf FACE).)
For people who've written assembly on other platforms, I'd compare it to writing Intel assembly v. MIPS/RISC style. The Intel platform is convoluted and very CISCy, whereas MIPS-esque processors have fewer, simpler instructions.
At least AVRs dont have 'memory banks,' a true horror that makes hand-written code, especially that with interrupts, nigh impossible.
Winner? On the matter of assemblers, its a tie but in the matter of assembly itself, AVR is a clear winner.
C: C is a great language for microcontrollers: it was developed back when mainframes had computational power/storage on the order of a modern microcontroller (!). As a result, it's lightweight, fast and doesn't come with useless stuff like garbage collection or 'objects' but does come with arrays, functions, pointers, etc. For PICs, the 'standard' compilers are from HiTech and CCS for windows. I've used CCS and found it usable although it had some odd additions: it wouldn't let me compile code that 'could' overflow the stack. However, it does have a lot of nice macros built in. Steve M. writes:
I like targeting the ultra-low-end devices and horse-traded with CCS for their $450 C compiler. It's not ANSI C by a long shot and isn't even case sensitive (!), but if I hold my mouth just right it usually compiles my code well enough. But its greatest liability is that huge swaths of functionality are "built-in" to the compiler (it has no linker), which means that every week when Microchip comes out with a new part your compiler becomes obsolete. All you need to do is update the compiler, but that costs $250 a year for "support" that I otherwise wouldn't use. So since my license is 2 years old I just live without the cool new tiny 10F series and anything else new. HiTech C seems like a better (ANSI) compiler but it's $1000 and still requires $250/year "support" to keep up to date on the devices. Very irritating.
There's also, apparently, a free compiler for PIC but I havent heard much about it. Can someone send it in a note? There is a free compiler for PIC available from Microchip, Dan Nguyen writes:
About the free PIC compiler, you just download it from the Microchip
website and you can use it in the Microchip MPLAB IDE. IT's actually
the student version and the only difference is that all features are
only enabled for the first week. After that the only thing that changes
is you can only have the compiler "optimize" your code to level 2
instead of all the way- but most of the optimizations aren't needed at
all and if you like your code to run exactly how you typed it,
optimizations aren't for you.
Microchip says it doesn't update it as frequently as the paid version
(but that's understandable).
There's also SDCC which I used to use a long time ago and was not a fan of. However it is free and open source and compiles C code for many (but not all) of the PIC devices.
On the AVR side pretty much everyone uses avr-gcc, a targeted version of gcc for the AVR microcontroller. Theres a lot of good things about it. One, it's completely free & works for Macs, Linux, Windows in a nice distribution. Second it's 'real' C, which is great when you want things like standard libs, includes, linking, unions, structs, and pointers (CCS at least, struggled with these). It also means that porting code is really easy because everyone uses it (all of PIC compilers aren't 100% compatible). Third it generates good (fast, small and correct) code: the optimizer is the same as in every other gcc.
Winner? I'm giving this one to AVRs: a free high quality compiler with full optimizations, constant updates, supports all devices, and that is completely cross platform? Hard to compete!
BASIC: I dont write code in BASIC so I dont have a lot of information on this. I know that the Parallax BASICstamp boards are popular (see below). I believe that they use the microEngineering Labs BASIC compiler and I'm sure this compiler is pretty good. $99
On the AVR side, there's BASCOM. Also havent used it. $99
Winner? Lacking more information, I think it's a tie.
Software Integrated Development Environment (IDE)
I don't know too much about IDEs although I have played with both AVR Studio as well as MPLAB and many people say that MPLAB is superior. Granted, I haven't used the most recent MPLAB (I quit it around 5.x). They're about the same, offering an easy assembler access.
Winner? Tie!
Caveat: Neither have reasonable C-compiler support, and both only run on Windows. Mac? Linux? You don't get an IDE, roll one yourself.. So they both lose in this regard
Note: Eclipse has been suggested to work with WinAVR but I couldnt quite get it to work myself. YMMV.
Note2: CodeBlocks supports both PIC and AVR and FIRST uses it. If those teenagers can do it, so can you!
Full Development Boards
So you want to start playing around, a good place to start is a full Development board. The two compared here are from the manufacturers:
PIC Kit 1: this is a relatively new little USB powered board that comes with a bunch of LEDs, a prototyping area and an RS232 converter.. An ideal starting point!
Pros: Simple, straight to the point, useful manual, and $40
Cons: However, no buttons, or anything else other than a few LEDs and only supports a handful of chips.
STK500: An old stand-by. Tons of stuff including LEDs, buttons, eeproms, variable oscillators, power supplies etc. $80.
Pros: Full featured, the end-all-be-all of dev boards
Cons: Twice as expensive, serial port not USB so you need a converter for Macs or some PCs
Winner? I'm leaning towards the PICKit1 here, since its cheaper.
"Beginner's" Dev boards
These are slightly different than the 'open ended' dev boards above. These are more for people who are really starting for the first time with Microcontrollers. There are two real options I see
BASIC Stamp: This ubiquitous little package from Parallax pretty much dominates the market and is their bread&butter. Programmable in 'BASIC', a PIC with a BASIC interpreter + some eeprom (for storing instructions) + RS232 converter = Drop in solution for many educational/robotics projects. $44
Arduino: An up and coming condender for "BASIC Stamp killer", this is actually much larger (a small dev board instead of 'chip' sized). Programming is done in "proce55ing-like sketches" that are pretty much C with some macros. Comes with USB instead of RS232. $32
Winner? At this point, BS is losing traction to Arduino. So AVR wins!
People support
PIC's and AVRs both have substantial support forums at PIClist and AvrFreaks. From cursory observation, the fact that AVRfreaks has a full featured website with forums (with threads!), projects, archives, RSS, device comparisons etc. gives it ++ points of a mailing list that from their own admission is constantly inundated with requests to unsubscribe. It does have a projects selection and archives, despite the webpage looks like it was made in 1997. (I dont particularly think that mailing lists are an effective way of sharing electronis info for beginners)
On the other hand, both sites have badmouthed me & this page so I'm takin this prize away! :-)
Winner? Neither!
Integrated Extras
One of the things you may want with your microcontroller is some weirdo-extras like Ethernet, CAN, RF or USB support
I know microchip has an Ethernet PIC (although I have no experience with it), and the USB PICs have been around long enough to be stable.
Atmel, on the other hand, hasn't seemed to go this route so if you want hardware USB support built in, you should go with a PIC! (On the other hand, there have been many examples of bitbang-USB successes for the AVR)
Winner? PIC!
by 进化中的兔子 发表于:2011/9/10 11:41:28
My subject | 我的主题
New entries | 新发表
Messages Board | 留言板
Guest Comments | 新评注
Blogger Login | 登陆栏
Blog Infomation | 信息栏
博客名称:嵌入式系统&虚拟仪器 日志总数:450 评论数量:277 访问次数:1781405 建立时间::2005年10月25日
Blog Infomation | 搜索栏
Blog Infomation | 收藏栏
XML RSS 2.0
嵌入式系统&虚拟仪器
© COPYRIGHT 2004 ALL RIGHTS RESERVED http://www.gkong.com
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
