My Blog! blog.gkong.com
Tip of my blog
新年快乐!
阅读(1905) 评论(0)
标签(TAG):
6)STM32 Independent Watchdog Example
The STM32 IWDG example program shows how to configure and use the Independent Watchdog of STMicroelectronics STM32F103xx microcontroller.
The independent watchdog is configured to fire after 2 seconds. LED PB15 indicates that the IWDG is no longer reloaded and is now going to reset the board. LED PB12 is lit when the restart was caused by the IWDG.(2009)
stm32_iwdg.rar (2009)
5)STM32 SVC Example
The STM32 SVC example program shows how to use software interrupt functions with STMicroelectronics STM32F103xx microcontroller.
The example includes file SVC.c which implements the SVC handler. The SVC function declarations and implementations are demonstrated in the file Test.c.
stm32_svc.rar (2009)
4)STM32 Realtime Clock Example
The STM32 RTC example program shows how to configure and use the realtime clock of STMicroelectronics STM32F103xx microcontroller.
The RTC is configured to generate an interrupt every second and also when the alarmtime is reached. Time is set to 12:00:00 and alarmtime to 12:00:20. LED PB8 blinks in a second interval and PB10 is lit upon an alarm interrupt.
stm32_rtc.rar (2009)
3) STM32 Timer Example
The STM32 Timer example program shows how to configure and use the timer TIM1 of STMicroelectronics STM32F103xx microcontroller.
TIM1 is configured to generate an update interrupt every 250 ms. The lit LED moves on every timer tick.
stm32_timer.rar (2009)
2)Assembly example with RealView MDK
The Assembly example shows how to create a pure assembly program for an ARM device. It is done using the RealView Compilation Tools that are part of the RealView MDK-ARM.
qzm Note: 随着32位MCU的市场占有率的提高,用嵌入式C而不是汇编是大部分人的选择,但具有汇编程序功底的开发人员能更好地掌控整个系统。
arm_assembly.rar (ARM公司提供的FOR MDK,IN 2006)
1) Stm32 CAN Exampe
The STM32 CAN example program shows how to configure and use the CAN peripheral of STMicroelectronics STM32F103xx microcontroller.
The CAN controller is initialized for 500 kbit/s. A converted analog value is send in the first byte of a CAN message. Received and transmitted byte values are displayed on LCD. (2009)
The configuration of the clocks is done using the Configuration Wizard in file STM32_Init.c.
stm32_can.rar  (2009)
by 进化中的兔子 发表于:2009/1/14 13:48:11
My subject | 我的主题
New entries | 新发表
Messages Board | 留言板
Guest Comments | 新评注
Blogger Login | 登陆栏
Blog Infomation | 信息栏
博客名称:嵌入式系统&虚拟仪器 日志总数:450 评论数量:277 访问次数:1781235 建立时间::2005年10月25日
Blog Infomation | 搜索栏
Blog Infomation | 收藏栏
XML RSS 2.0
嵌入式系统&虚拟仪器
© COPYRIGHT 2004 ALL RIGHTS RESERVED http://www.gkong.com
中华工控网 | 联系我们 | 工控论坛首页 | 工控博客首页 | 博客注册 | 博客登陆
工控博客管理联系邮箱:工控博客服务邮箱
中华工控网 © Copyright 2013. All rights reserved.
